MITSUBISHI OPB20T s/n: OP20T00026 ALARM 075
can anyone help me with the above erro code.thank you
  • Posted 20 Oct 2011 17:47
  • By mapapada
  • joined 12 Oct'10 - 44 messages
  • attica, Greece
good luck
thank you very much i will check it
  • Posted 20 Oct 2011 21:12
  • By mapapada
  • attica, Greece
good luck
2) CONTACTOR DRIVER
MDI-PRC Code = 75
- Cause: This alarm occurs when the voltage on the Main Contactor is
smaller than expected: this means that the Main Contactor Coil
has a null voltage when supplied.
- Remedy: Check the coils of the Main Contactor (CNA#1) is not short
circuited. If it isn't, probably it is necessary to substituite the
controller because the driver of the Main Contactor is broken.
hope it helps , regards
  • Posted 20 Oct 2011 21:05
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Tusk 500PGH14
Aichi SR18A
RAEDER-VOGEL
Kai von Berg Kai von Berg
