Linde H45D
Hello all!
I have Linda, and it gives me an errors:
L222
L237
L255
Help please someone who can!
I would greatly appreciate
  • Posted 20 Sep 2011 00:06
  • By flair_tof
  • joined 5 Aug'11 - 102 messages
  • Riga, Latvia
sales.lv@alimper.eu
Thank you very much!
  • Posted 21 Sep 2011 17:13
  • By flair_tof
  • Riga, Latvia
sales.lv@alimper.eu
Flair;
What you now need to determine is which jowstick isn't in neutral position when the key switch is turned on which is the cause for the L222 fault. The one thing which Linde AG pressed home in their training programs was guessing at the reason one may be right 20% of the time and dead wrong 60% of the time. Therefor, for every code there needs to be additional diagnostic.
An L237 is saying that the safety processor is seeing a value for a potentiometer reading that doesn't add up to an acceptable number range.
The L255 fault is a issue in the electrical control circuit of the tilt function which is spelled out in the previous post. However to add the tilt solinoids are the upper and lower solinoids on the control valve block which are next to the two solinoids which have the metal data tag attached. also look closely at the 10 pin plug/socket connector of the valve block. The next place to look is the controller plug/socket along with the controller itself.
  • Posted 20 Sep 2011 02:23
  • By MEngr
  • Missouri, United States
L222 = Joystick not in neutral position for more than 2 sec after Power On
L237 = Incompatibility between signal/reference potentiometer AUX1
L255 = Solenoid current tilting too low
Check the joystick isnt stiff / dirty
Check / clean the connector plugs, also check for any wiring damage.
  • Posted 20 Sep 2011 00:49
  • By Forkingabout
  • england, United Kingdom
Komatsu FD25T17
Elwell-Parker ESI500-36
Komatsu FD25T17
Komatsu FD25T17
