LINDE R20 113 1998
Hi i have a R20 so this can not tilling 2000 kg, only 1000 kg and the lift cilinder stops so the pump turn max i think it is the pressure relief valve but i have check this and turn this to the max so it not helps. Is it possible the pump does not give the oil pressure the truck need for more than 1000 kg?
  • Posted 9 Sep 2011 04:02
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
pomp was versleten, met nwe everything oke.
Thanks all
  • Posted 12 Sep 2011 18:25
  • By gc_d
Regards gc_d
12000 uur dus dit zo kunnen , ga morgen ander pomp monteren dus ben benieuwd.
  • Posted 12 Sep 2011 04:35
  • By gc_d
Regards gc_d
ik weet niet hoe veel uur deze truck heeft maar aan leeftijd te zien weet ik haast zeker dat de pomp overleden is
groetjes michel
  • Posted 11 Sep 2011 02:18
  • By michel_v
  • noord holland, Netherlands
Hi ac d;
Has the oil in the tank been changed or added too recently? Also, Has a check of the hydraulic pressure cap been done? The pump creates flow and pressure is a measure of resistance to the oil's flow. To determine the efficiency of this truck's pump is to relate it to the volumn of oil change (speed of lifting change unloaded vs loaded).
  • Posted 10 Sep 2011 00:27
  • By MEngr
  • Missouri, United States
Hi ,no i go next week to check this but what you say about the pump it is possible i think to internal leakage
  • Posted 9 Sep 2011 21:04
  • By gc_d
Regards gc_d
Yes ,is possible if you have a pump with a lot of wear,that causes internal leakage.
Did you checked the pressure before and after you tune the relief valve?
  • Posted 9 Sep 2011 20:52
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
SMV (Konecranes) 4632CC5
UN Forklift FGL18T
Kai von Berg Kai von Berg
