Installation of back up alarm for BT reach truck (model:RR N2/14; s/n: 279234/1996)
Does anyone could share the wiring to install the back up alarm on the above BT reach truck (s/n: 279234/1996).
Appreciated your kindly help!
zhou
at
skset
dot
com
  • Posted 30 Jun 2011 22:46
  • By joel_zhou
  • joined 5 Mar'09 - 31 messages
  • singapore, Singapore
connect 1 piece 48V small relay with reverse contactor's coil. it works but useless due to the 360 steering degree. I will try to connect to the direction switch tomorrow!
  • Posted 6 Jul 2011 00:55
  • By joel_zhou
Let us know how you get on with it, i've never wired one of these up to a DC Reflex, not many of these left any more in the UK.
  • Posted 2 Jul 2011 00:31
  • By Forkingabout
  • england, United Kingdom
u r right, will try to get a 48V relay connect to reverse contactor tomorrow! Thanks!
  • Posted 1 Jul 2011 07:46
  • By joel_zhou
Hi
Reflex DC, not seen one of these in a long while.
Pin 409 is the steering wheel refrence 180 degree sensor & this is 48 volt
I think your gonna need a couple of relays to get it working.
A colleague of mine still looks after some Reflex DC's, ill ask him if he knows anything about fitting a warning alarm.
  • Posted 1 Jul 2011 07:21
  • Modified 6 Jul 2011 17:44 by poster
  • By Forkingabout
yes,is DC motor. The back up alarm is 48V (same as truck volts)
  • Posted 1 Jul 2011 06:43
  • By joel_zhou
From the serial number it look's like its gonna be a DC truck.
If it's a DC Reflex then there will be 2 direction contactors buired under the dash / armrest panel right at the front.
How many volts is the back up alarm?
  • Posted 1 Jul 2011 00:30
  • By Forkingabout
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion FB25LI
