Code 228
Could you tell me what code 228 is? Unit also displays on the LCD left pedal switch discharge.
Thank you
  • Posted 4 May 2011 08:43
  • By jeremy_m
  • joined 4 May'11 - 10 messages
  • British Columbia, Canada
thank you, Tommy, I really appreciate your help.
I will check the pump motor.
kind regards,
  • Posted 7 Dec 2023 22:49
  • By RamKhudan
  • joined 4 Feb'21 - 54 messages
  • Curacao
Ram
ramkhudan@gmail.com
I would recommend testing your pump motor as it may be grounding to the case.
  • Posted 7 Dec 2023 10:32
  • By DyslexicNerd_01
  • Wisconsin, United States
good morning
Crown 5200 D.C.
I am having the same issue code 228. after Troubleshoot and replaced the ED contactor, fuses, battery connectors check all connections and replaced access 2 and 3, after all this code 228 still comes back.
i don't know what to check now, please any advice on how to proceed? I appreciate your help.
  • Posted 7 Dec 2023 01:20
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
also if battery has been worked hard, pump motor brushes could be slightly swollen and stuck in brush holders making poor contact with com bars..,
  • Posted 11 May 2011 22:36
  • By julesrobdog
  • joined 13 May'09 - 11 messages
Thank you very much, that is very helpful
  • Posted 5 May 2011 02:12
  • By jeremy_m
jeremy m,
Check the pump motor power fuse (FU8). Also, look at the condition of the ED tips, Cables, Battery Connection, etc.
Code 228 is related to the items above. If all check good replace access2.
  • Posted 4 May 2011 09:21
  • By Miloslouis
  • joined 4 Dec'10 - 27 messages
"Freedom of the Road"
