Nissan CSP01-L18S PS Trouble
Getting a "PS Trouble 514,530 013" error code. The power steering has stopped working. Had no problems with the PS one day, the following it didn't work.
  • Posted 22 Apr 2011 10:10
  • By MacMedia
  • joined 22 Apr'11 - 4 messages
  • Arizona, United States
Showing items 1 - 20 of 22 results.
I just encountered the same problem.
Did you ever get that manual? If yes would you mind sharing a copy?
  • Posted 5 Feb 2022 07:40
  • By Jason_Clark
  • joined 5 Feb'22 - 1 message
  • New Hampshire, United States
JC
Very old post i see but i hope someone reads this and is able to send me a service manual?
  • Posted 5 Nov 2021 21:43
  • By Forklift_tech
  • joined 5 Nov'21 - 1 message
  • Netherlands
I know this is old, but I too need a power steering circuit schematic.
  • Posted 19 Jun 2018 03:00
  • By boogerstooger
  • joined 19 Jun'18 - 2 messages
  • Oklahoma, United States
Hi, Similar PS Trouble 013 fault with *514/*526. found big ceramic resistor with only 1.5Ohms - should be 10M Ohms. Could this be the issue?
  • Posted 2 Nov 2017 17:05
  • By trevi_e
  • joined 2 Nov'17 - 1 message
  • Queensland, Australia
Cheers.
What company did you send your card to? @MEngr
  • Posted 1 Apr 2016 03:31
  • Modified 1 Apr 2016 03:33 by poster
  • By Machinmaniac77
  • joined 1 Apr'16 - 1 message
Thank you much for your response, the information is appreciated. That is an odd mix of codes. The only two that seem to correlate are the 514 and 526. I don't believe there was a 530 or 531 but l will make sure to run the diagnostic system again on Monday morning.
  • Posted 18 May 2013 10:38
  • Modified 19 May 2013 00:03 by poster
  • By fd25t6
  • joined 31 Jan'12 - 11 messages
  • New Jersey, United States
fd25t6;
The 524 is a traction control current sensor issue, while the 514 can be a short or open transistor issue with the power steering, depending as to if there is a 531 or 530 code also. Now the 526 fault could either be a power steering open in the large resistor or the small resistor which could be better defined if there occurred a 530 or a 531 fault also.
  • Posted 18 May 2013 07:57
  • By MEngr
  • Missouri, United States
Hey now, I'm also getting the 514 followed by a 526 amd a 524, was wondering if anyone had a definition for the 524 in particular. Thanks in advance.
  • Posted 18 May 2013 02:36
  • By fd25t6
roc109;
Repairs of board done in Georgia-USA.
  • Posted 19 Apr 2012 21:45
  • By MEngr
good luck repairing those boards,flight systems cannot touch those
  • Posted 19 Apr 2012 10:00
  • By roc109
  • joined 2 Nov'09 - 51 messages
ok thanks MEngr !!!
I don´t know the logical of nissan trucks!! I will see this points
regards
  • Posted 17 Apr 2012 20:48
  • By andres_v
  • joined 9 Dec'09 - 37 messages
  • CABA, Argentina
Always in movement
Andres;
You need to perform interactive dianostics of the truck's control to define the power assist steering issue. The way to do this is to push FN 1 and FN 4 in while you simultaneously turn on the key switch. You will see the self check menu in the display screen. The power contactors in the power distribution panel will all close and open in an orderly sequence. Push the FN 3 Diagnostic check window 500 should now appear. Now push FN 1 Error Memory window 510 will appear. Malfunctions which have occurred in the traction, loading, and power steering systems are recorded.
  • Posted 17 Apr 2012 12:32
  • By MEngr
Hi Mate
If all those checks are ok I guess it points to the main pcb. As this also feeds the power steer circuit.
  • Posted 17 Apr 2012 03:31
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hello everybody!
I have a NISSAN P02 truck (model QP02L20U). When the trucks is ON, automatically appears on display "PS TROUBLE 013". The PS contactor is not actuated, and the electric steer is not working. I did some verifications:
1) On the back, I disconnect the steer motor cables, and tested the steer motor with 30V conecting. The motor worked ok, without problem to the booth sides.
2) Check the potenciometer (steer sensor) cables on back. I disconnected the CN2 plug on the main controller, and then tested the poti values. Are ok!
3) I checked the PS contactor coil resistance value, aprox 260 OHMs, is ok. The cables are ok.
4) IGBTs power transistors are ok, and the connections wires (CN1) for to control them are ok too.
5) I conected the truck ON, and at the same time I pressed manually the contacts of the PS contactor. Nothing happened. There is not a short circuit on the power circuit, because when I closed the PS contactor´s contacts nothing happend.
please help me!
best regards
  • Posted 17 Apr 2012 01:32
  • By andres_v
  • CABA, Argentina
Always in movement
Does anyone have a schemtic of the power steering section?
  • Posted 7 Dec 2011 22:32
  • By clifton_t
  • joined 18 Nov'11 - 6 messages
clifton;
The * mark ahead of the fault code number is present to inform you that the truck in question has multiple malfunctions occurring. 514/530 fault codes are saying that there is a short in the power steering power circuit. Look for an armature short in the power assist motor. The 526 error is a PS current sensor that has an elec. open. 510 is the self dianostic check window.
  • Posted 18 Nov 2011 07:48
  • By MEngr
what does the * tell you. I have a truck that gievs me *514, *526, *530 also 510 contact failure. Have CWP02l25S s/n 9C1981
  • Posted 18 Nov 2011 01:43
  • By clifton_t
You have a truck that came off the assembly line after Dec 97. The error codes appearing on the display are saying you have a short circuit condition in the traction drives power circuit. Check to see that the truck's chassis is electrically clean. Do this by removing the battery from the truck and having it connected to the truck while outside of the truck. With the drive wheels raised off the floor, battery as described, push buttons 1 & 4 down and turn key switch ON press button 1. Wait till all switches have stopped clicking note any and all error number that appear, also if an asterisk mark precedes the number code. Is this truck equipped with speed controlled hydraulics. Push button 3 will take you to window 500 (lower right corner) button 1 error memory screen 610.
  • Posted 10 May 2011 14:29
  • By MEngr
Mengr - similiar code 530 in addition to a fault code 512 on
a CSP01A15S - any help would be appreciated!!
  • Posted 10 May 2011 06:54
  • By HeavyHauler
  • joined 10 May'11 - 1 message
MacMedia;
IGBT Trans P/N 29327-2K011-F1
Send Print board to Flight Systems -Mechanicsburg, PA. and see what they say. There are quanity of 12 different print boards that could be. Which one of the 12 is known thru research and/or crossing over the Hitachi No. to a Nissan P/N.
  • Posted 22 Apr 2011 13:40
  • By MEngr
Toyota 3FD100
Morooka MFD20
