linde t 20 ap
hi guys i have a promlem with a linde t20 ap its a ride on power pallet truck. i have fault code t 206 ans s1 257.
it wont drive lift or steer when you turn it the relay closes and then the fault code shows.
  • Posted 15 Feb 2011 00:09
  • By Mag1
  • joined 24 Feb'06 - 25 messages
  • CO DUBLIN, Ireland
T206 in 131's means the LES (steer module) isn't turning on the LAC (Traction/Lift module - the big one). All start up conditions for steer must be met before the LES will turn on the LAC.
S1 257 - relates to the pre charge capacitor cct , so looking at the LES module or precondition feeds into the LES
  • Posted 28 Apr 2011 12:09
  • By Lookingglass
  • joined 28 Apr'11 - 2 messages
  • Queensland, Australia
stiil in trouble with it i found a problem with the large contactor on the l/h/side the hydraulic contact the coil was burned out.
i replaced it with a new one and tried it again still the same faults. checked brake wiring pump solonoid wiring and others you mentioned still no luck.
looks like i have to bow to linde and get main dealer in.
unless you can suggest another option.
  • Posted 17 Feb 2011 11:45
  • Modified 17 Feb 2011 11:47 by poster
  • By Mag1
Hi john b
How did you get on with the Linde fault?
  • Posted 17 Feb 2011 05:53
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
thanks for the quick responce powerlifter i will try them out tomorrow and let you know how i get on
  • Posted 15 Feb 2011 06:14
  • By Mag1
Hi John
Code 206 Battery voltage too low (<9v) Information sending from display.
Fault 257 Problem at safety relay output voltage at pin X1:24 is greater than voltage at pinX1:1. Reasons may be: shortcut to battery voltage at an output pin (e.g.brake pin X1.49.main contactor pin X1.2,valve pin etc) also check for broken wires upto brake soleniod.
Hope this helps let me know how you get on.
  • Posted 15 Feb 2011 02:16
  • By powerlifter
A good engineer is a helpful engineer
Komatsu FD25T17
Taylor TXB180S
Komatsu FD25T17
Taylor TXB180S
Komatsu FD25T17
Taylor TXB180S
