Hyster J3.20xm
Code 127 low voltage
I did measerment cable Nr 50 from Traction 12v and 1 minit later O volt I did take of 12 volt of batterij to pin 10 of lift controller everything oke But now every time code 127 low voltage no hydraulicks Reset with contact he works fine for few hours and then again code 127
And how much Voltage I made give to Liftcontroller on pin 10 (LI) Are there specs of controller there standing on the voltage of the pins. What is the problem the Controller!!!
Regards
John
  • Posted 30 Jan 2011 05:52
  • By johngen
  • NB, Netherlands
Hi John
It does sound like a controller problem. If you start the truck up before operating anything either lift or traction is the error 127 present? if so then most likely controller related problem.
  • Posted 31 Jan 2011 07:45
  • By elektrodrive
Elwell-Parker ESI500-36
Toyota 8FG25
