Clark
I have been shopping for a different machine and curious about model numbers. I am replacing a C500-70. Wanting something pnumatic to be more suitable for a gravel parking lot. What is the difference between a Clark C300-Y40 & a C500-Y40? Also sometimes I see a HY suffix machine?
Thanks
Murphdog
  • Posted 26 Jan 2011 21:18
  • By Murphdog
  • joined 26 Jan'11 - 1 message
  • Missouri, United States
I know im kinda off topic but I recently purchased a C500
Ship date: May 1975
Model#CHY160D
Serial#HY1625-14-3061
It ran great when I got it a week ago, with no problems from the hydraulics. the guy I bought it from said it needed some hydraulic fluid added to it because the steering ram leaked a bit. When I went to fill it the only place i found to fill it was from the dual filter units under the seat behind the side plate. When I removed the cover from the front filter tube, I heard a ?suucking? sound. After putting 15gal into the tank and sealing the filter unit back up, the hydraulics felt like they were full of air (jittering, loud groans from the pump, settling of the forks 8"-12" after stopping vertical lift) I noticed later that the main Hyd. pump is fed from the top of the tank from the filter tubes. which means the hyd. fluid has to come up from the tank through the filters and into the feed tube. Im assuming that I bleed off the pressure/vaccum that was present in the filter tubes, causing the air problem.
My question is: Is there a specific way to "pressurize the system" after changing the filters and adding fluids, and if any one knows where i can find a service manual for this particular Forklift?
I checked the Clark dealer locations and called the dealer in Milwaukee, Or. They said the service manual was no longer available but the operators manual was, along with the parts manual. They were also unfamiliar with a Hyd. system that old. The guy I spoke to said he would try and see if he could locate their copy of the service manual and have it copied for us but I'm not holding my breath.
Would the operators manual have anything on this issue in it?
Any help is appreciated.
Will
*Edit* had to change spelling of S., U, C. K. Ing due to Censoring LOL
  • Posted 2 Feb 2011 10:19
  • Modified 2 Feb 2011 10:29 by poster
  • By Willah
  • joined 2 Feb'11 - 1 message
  • Oregon, United States
The C300Y40 was a cheaply made copy of an older Clark model CY40. Most of the parts, except for the engine, are hard to come by for this truck. I would not recommend it at all. The C500Y40 was a great truck for Clark with excellent parts availability. As a matter of fact a lot of Clark people like it better than anything they've come out with since.
The HY stands for hydrotork transmission which is a 2 speed automatic.
  • Posted 28 Jan 2011 22:37
  • By duodeluxe
  • United States
duodeluxe
Libiao Robotics
