slow travel......EZ-C
hi everyone....a little help here...i have a raymond ac drive and pump...the problem is the drive motor turn slower there is no error codes pop-up. The drive controller looks fine. I observed the two cable in a drive motor hot. This unit is use in a cold storage. any suggestions and opinions?
thank you in advance
  • Posted 13 Jan 2011 14:39
  • By forkliftcity
  • joined 23 Jul'10 - 52 messages
  • cebu, Philippines
don't bite the hands that feed you!
hey thanks for the reply. i think the lower bearing is defective i find that the lower arm in the drive unit misaligned. there is no 6k in the display..the cables looks fine..I'll let you know all if the unit is ok.
thanks again more power and God bless us all
  • Posted 18 Jan 2011 17:56
  • By forkliftcity
  • cebu, Philippines
Brakes dragging are common, bad lower bearing will slow things down. 6K is common when staging and 1st speed limiting switches dont agree. This will cause slow travel because VM thinks the carriage is out of free lift. carriage switch gets plastic often, top switch gets bent arm.
what is battery value when lifting? Are the battery cable pins soldered? should be.
Most important, are the cables from drive amp to drive motor discolored or burned....replace befrore they take out drive amp...
  • Posted 15 Jan 2011 08:17
  • Modified 15 Jan 2011 08:21 by poster
  • By EasiTek
hey edwar t, thanks for the reply..the bearing looks ok when the bearing is defective it throws a code 2f i think....
  • Posted 14 Jan 2011 13:51
  • By forkliftcity
  • cebu, Philippines
sounds like an encoder bearing to me...
  • Posted 13 Jan 2011 21:29
Sue Tomic Sue Tomic
TCM FD115-3
Komatsu FD25T17
