EP18KT
I have a EP18KT truck serial # ETBSB01187. I replaced the H bridge card and now it set code 01 and says app-6. Any help would be greatly appreciated, this truck is my nemisis. My email is dpw1993 at hotmail.
  • Posted 4 Jan 2011 06:28
  • By dale_w
  • joined 23 Jun'09 - 48 messages
  • Missouri, United States
Dale W,
Edward is right about seat switch, but option six refer to auxiliary 2 speed which would sugest you have a four way control valve Im guessing at that, and re to speed settings for attachment 2 range 1-10 default value 1 could 1 in this case be re speed op6, if so cycling the DRS switch S to R toS will go through the options till the word done appears switch trk of wait awhile and switch trk back on this should give you a normal display, do not sit on the seat while you cycle the switch, you know you have to pull the stem of the DRS out before you cycle it,
Titus
  • Posted 5 Jan 2011 05:59
  • By Titus
  • joined 6 Jul'10 - 185 messages
code 01 is the seat switch
  • Posted 4 Jan 2011 09:15
Maxlion FDR45
Rail King RK330
GemOne
