clark hydraulics
cgp 25- loses hydraulic oil out the breather vent when lowering mast quickly, also will pop the resivour dipstick out. Return filter ok, breather filter ok, oil level ok
  • Posted 1 Dec 2010 12:14
  • By liftguy
  • joined 29 Sep'10 - 8 messages
  • British Columbia, Canada
Hello
Its A old problem of Clark
There is A modifaction kit for it
No plastic more But steel case now
Regards
John.
  • Posted 12 Dec 2010 23:11
  • By johngen
  • NB, Netherlands
Found the problem. pulled out the filter asembly in the tank and found the plastic housing in the filter assembly was cracked allowing the return fluid to bypass the filter and go in to the vent area of the assembly
  • Posted 7 Dec 2010 12:22
  • By liftguy
  • By liftguy
You may be on to something there Lumberjack, I know nothing has been altered on this unit but it does lower rather quickly in my opinion. I have never had to change a velocity fuse on the main lift line before though. Is there any flow control in the lift spool valve in the control valve?
  • Posted 4 Dec 2010 08:49
  • By liftguy
I haven't had Clarks for awhile but every Clark I've ever worked on has had a flow control valve at the base of the lift cylinder. This should slow lowering to a reasonable speed even if the lift line breaks.
Does it do OK if you lower more slowly? If the load comes down like someone dropping a flower pot from the roof, that's the real problem. A new breather cap wouldn't hurt either, even if the old one seems clear.
  • Posted 3 Dec 2010 16:01
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
You might want to check the mast lowering control valve (maybe some one removed or modified it to allow the mast to lower faster). Not certain if this unit has a baffle plate or diffuser in the but if they are missing or damaged it could cause this issue.
  • Posted 2 Dec 2010 21:38
  • Modified 2 Dec 2010 21:41 by poster
  • By johnr_j
liftguy, get a look inside the tank to see where the return is dumping it sounds like the connections to the tank may have been swapped.
  • Posted 2 Dec 2010 11:08
  • By steponmebbbboom
Hi i have c500 y30 it is doing the same i have replaced all orings in valve control but still the same if you find out whats wrong let me know if i find problem will let you know.
  • Posted 2 Dec 2010 09:12
  • By sherene_g
  • joined 1 Dec'10 - 4 messages
  • New South Wales, Australia
norton 38
