more Hyster S50XM questions
ok I managed to get ahold of a wiring schematic but am unlcear as to early model versus late model. does anyone know what the serial number break is that determines this? also my coolant level light is on constantly but it has coolant. anybody know where the sensor is located for this? its a 1996 with the mazda FE engine. its not on the radiator or the recovery tank and I cant seem to find it on the engine. unless Im not looking in the right place. found the coolant temp sensor but not coolant level. thanks for any help.
  • Posted 19 Oct 2010 20:45
  • By craig_f
  • joined 26 Jul'10 - 26 messages
  • Iowa, United States
ya know I saw that terminal on the pass side of the radiator and the wire is broken off. looked like a ground at first glance. but I just went and took a closer look and you are correct its a very small sensor. thank you.
  • Posted 25 Oct 2010 14:21
  • By craig_f
hi craig,
ive seen the level sensor on XM rads before, it is indeed installed in a bung on the top tank. it is possible that the radiator was replaced at some point with a "universal-fit" or simply incorrect fit radiator without this provision, an dthe ring terminal was just left to hang loose and is shorting out on the frame. you will find the wire for the level sensor poking out of the wire harness that passes over the top of the radiator.
  • Posted 25 Oct 2010 14:15
  • By steponmebbbboom
Hey hows it goin? the service manual says its on top of the radiator but theres not one there.
  • Posted 25 Oct 2010 07:52
  • By craig_f
Hey Craig,
I hope someone on this network can help you,
once again, pleasure doing business with you
  • Posted 25 Oct 2010 06:09
  • By rrforklift
  • joined 3 Sep'04 - 8 messages
Faizal Jamal
R&R Forklift Inc
SMV (Konecranes) 33-1200C
Big Joe PDR30-154
USD7,500
