Idle adjust
anyone know how to adjust the idle for this truck? it's 2004 FG30SHT-14 and has nissan engine.
  • Posted 15 Oct 2010 12:51
  • By li_w
  • joined 16 Nov'09 - 49 messages
could you please let me know what you mean about the 5 on 5 off sequence? i have a kalmar ac with the k21 and no diagnostic port or on board options and need to relearn idle air volume.
  • Posted 10 Jan 2025 00:33
  • By kevin_yates
  • joined 10 Jan'25 - 1 message
  • Michigan, United States
Komatsu forklifts FG20-30, -14 can set the idle speed by doing the 5 on 5 off sequence and the third time 5 on and 20 off with the ignition switch !This relearns the ECU and the idle speed comes down to 750-800rpm. After if you have the analyzer , hoook it up and relearn the air fuel relearn the you're problem should be fixed.
  • Posted 17 Jan 2011 06:28
  • By Will
  • joined 17 Jan'11 - 1 message
If you aint gonna fix it right , then dont fix it. Gotta be perfect.
thanks for the info. it's nissan K-25 engine
  • Posted 1 Nov 2010 09:29
  • By li_w
If this is a K series engine, the idle speed is not adjustable. If the engine will not idle at 750-800RPM, there is a fault that must be corrected.
If it is an H20 with conventional Impco LPG system, there will be an idle screw on the throttle arm of the mixer. Ensure timing is at 10BTDC, intake and exhaust valves are adjusted properly, fuel mixture is set properly, then adjust to 750-800RPM. If the truck has a throttle dashpot on the opposite end of the throttle shaft, adjust the dashpot to 1200RPM with vacuum disconnected and ensure it releases completely with vacuum applied.
  • Posted 19 Oct 2010 08:50
  • By steponmebbbboom
Hello , need to know if your engine is a K21 or K25. also a Sn would be great
  • Posted 19 Oct 2010 07:35
  • By DennisW
  • joined 10 Sep'09 - 21 messages
November 13-14, 2025 - Berlin, Germany
Tampa, United States
Tampa/Orlando Florida, United States
Marietta, United States
Dallas, TX or Lexington, KY, United States
Steve Dimitrovski Steve Dimitrovski
Director sales for Australia and New Zealand, Swisslog
General Manager, Forkpro Australia
Global CEO, Swisslog
Board member, UKMHA
