BACK UP ALARM JUNGHEINRICH ETV114
HOW DO I HOOK UP A BACK UP ALARM
  • Posted 14 Sep 2010 05:55
  • By stanley_m
  • joined 14 Sep'10 - 3 messages
  • Illinois, United States
Hi There
Its possible if you make a circuit which is suppressed with a relay and get the relay to switch off the feed off the direction lever supply you may be able to do something. Then feed the reverse alarm itself through the relay contacts.
  • Posted 17 Sep 2010 02:48
  • By elektrodrive
THANK YOU FOR THE HELP
  • Posted 16 Sep 2010 23:08
  • By stanley_m
Hi Stanley,
Yes, your truck is ETV214 - 2008. I have spent for an hour to check in the drawing but I couldn't find out this function. It seems to be they don't design this function in this kind of truck.
The traction direction is controlled by AC and Canbus technology. When the truck come backward the only thing need to press the direction key then the canbus signal will send to controller and direct the controller to change the phase of the AC motor to make to truck change direction (not via direction contactor as the old model). Therefore, I see no way to get the signal to active the beeping alarm instruments automatically as you expected. You only can do it by manually. I do hope some experts on our forum can help you more.
Regards
Nuna
  • Posted 16 Sep 2010 15:25
  • Modified 16 Sep 2010 15:26 by poster
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
IT IS AN BEEPING ALRM WHEN TRK IS TRAVELING IN REVERSE, S/N 91055086
  • Posted 14 Sep 2010 22:05
  • By stanley_m
Hi,
I have checked in the device list of Jungheinrich but I don't understand correctly which lamp you need - your word "A BACK UP ALARM " ? this means reversing lamp or flashing lamp travel,...? tell your truck detail e.g. serial No. or year of construction ?
Rgds
Nuna
  • Posted 14 Sep 2010 18:37
  • By Nuna
  • BK, Thailand
Thanks & Regards
Nuna
Noblelift
