Recommended battery for hyster H3.0FT Diesel-powered forklift
Most operations on this truck depends largely on the battery. The question now is, which battery is recommended for use and what capacity - Is it the dry cell or the wet cell? 75AH, 100AH or 120AH? Any specific brand? Let me also ask - what reduces the life span of hyster batteries?
Ideas/information are welcome from all members in the house.
  • Posted 8 Sep 2010 03:36
  • By toby
  • joined 20 Jul'10 - 9 messages
  • Lagos, Nigeria
Alright thanks. What factors reduce the life span of a forkift battery - especially hyster.
  • Posted 8 Sep 2010 23:53
  • By toby
  • Lagos, Nigeria
hello Toby
battery recommended for the equipment depends on several points.
1 see the capacity of the alternator, never exceed the intensity of it.
2 to change to higher intensity of the battery, replace the alternator for the necessary
well as dry and liquid depends on what you want to use, and droughts are cleaner and you can use in any position
3 if it can be substituted by 75Ah 90Ah, 15Ah always a margin not to saturate the alternator and the regulator does not burn
the duration depends on the same tract that lead.
is worth remembering that the life of a battery depends on the effort required to verify where the same water levels. once dry enough to be sulfated
  • Posted 8 Sep 2010 08:02
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
Taylor THC500L
Mobicon 2T
