Hyster Code 62 - No Reverse - E35Z
Machine cuts off when placed in reverse.
Can anyone help with this code definition.
  • Posted 29 Jul 2010 23:08
  • By robert_c
  • joined 29 Jul'10 - 10 messages
Can you identify the location of the reverse relay, I am not aware of any external relay coils. Is it not built into the motor control box?
  • Posted 30 Jul 2010 22:51
  • By robert_c
Hi Rob
The fault code states that current to reverse relay is too high during operation.
It advises to check that the reverse relay coil is not short circuit or the wiring to it has no shorts. Disconnect the coil and check coil resistance which should be around 160 ohms.
It also states if the code displays with the coil disconnected then you probably have a fault in the master controller.
  • Posted 30 Jul 2010 07:12
  • By elektrodrive
Aichi SR10C1SM
Crown WP302020
Aichi SR10C1SM
Crown WP302020
