Toyota 7series45 Transmission (TORQUECONVERTER)
Hi sirs, somebody can explain what will effect the case sub-assy and extension sub-assy ( pump impeller) broken?
I already cahnge a set of new case sub - assy and the extension sub-assy. But i only can use my forklift for one day... i recheck again also facing the same problem as above.
Hope someboby can soft my problem. Thank
  • Posted 5 May 2006 12:24
  • By sandra
  • joined 5 May'06 - 1 message
  • Selangor, Malaysia
bad bearings? enigine side too
oblongated casings
cracked shafts?
broken roll pins in gears
bad mounts
pretty much anything catostrophic
u could have chunks of metal in the fluid
check the strainer/filter of the trans
  • Posted 12 May 2006 11:01
  • By justinm
Can you expand a bit more information on your question.
  • Posted 12 May 2006 08:01
  • By adrian_w
  • joined 18 Nov'05 - 33 messages
  • East Yorkshire, United Kingdom
Premier Mechanical Handling,
Hull.
UK
Terberg YT222
SMV (Konecranes) 16-1200C
Hawker Powersource, Inc.
Kai von Berg Kai von Berg
