000264
Pulling my hair out, 4 days on this machine and doesnt make sense, day 1 machine stalled and would not restart in a trailer, co-worker went out, replaced LPG coupler, wires plugs etc, regulator (he's about replacing parts, not trouble shooting) customer called me said he couldnt get it going, I come out, determine fire, and regulator, 1.5 psi, took apart mixer, cleaned reassembled, reset power valve, and fuel/air. no start, but was kicking, pumped accelerator a couple times, started and stalled when throttle was opened. Day 2 came back, checked and rechecked, fuel delivery, same thing, no start, but once in while would start but died when throttle opened, said I have to have a LPG problem, so got some gas (dual fuel) cleaned everything out primed it and it started, ran good for 2 minutes then died out, would not restart, checked distributer, I adfvance it all the way to the back of the machine, started right up, but had a small bind, as if the timing was off, but ran perfect, took distributor out and checked to see if it was off a tooth, wasnt, reinstalled advance all the way started up, ran perfect for about 30 mins, then died would not restart. day 3 took covers off timing gear, wound engine, checked TDC cam at 3 oclock, alighned with small mark crank notch alinged with notch in housing, oil pump gear off to 2 ocloc, looking with the frint of the engine, so timing is on, rechecked air gad on p/u,.35mm OK, still have fire. Day 4 machine started right up on LPG, ran great for 10 mins, then was sputtering but revved up, switch it to gas, ran good, same thing, sputtering but revving, dist still advanced, switch back to LPG, ran great for a wile, then dies, hard to restart but does restart. Ballest rester at I thin 6 or 60 ohms, had a short in the little switch in the carburator or solenoid, checked and rechecked vaccums, intake leaks, everything, it seems like a lean condition, but does not make sense to me what so ever!! non EFI, this should be simple, compression at 150 across the board, and when does start, runs great, unhappy customer and I'm at the end of my rope, Any bo\dy seen something like this, or any advise on what else to check could save my life!!!
  • Posted 22 Jun 2010 10:48
  • By Barfly_olaf
  • joined 10 Oct'09 - 81 messages
  • Nova Scotia, Canada
SEMPER FIDELIS
After more hair pulling, finally found out from the customer they overheated the engine, cmbine that with a dried up old intake gasket, and carb gasket, replaced them and machine runs great...er
  • Posted 25 Jun 2010 22:27
  • By Barfly_olaf
SEMPER FIDELIS
I'll try the vaccum, but no rattles from the exhaust, and when it does fire, she revs up no prob untill shes been running for a while
  • Posted 22 Jun 2010 20:18
  • By Barfly_olaf
SEMPER FIDELIS
just out of curiousity have you checked the vacuum at start up. had a very similar problem (not exactly same) that turned out to be a baffle in the muffler blocking the exhaust. when blocked , hard to start and no acceleration. when open, start and run good hit bump shut down hard or no start no acceleration. found problem with vacuum guage. probably not your issue but worth the 30 seconds to check.
  • Posted 22 Jun 2010 13:09
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
Terberg RT403
Manitou M50-4
