pdf for Jungheinrich gearbox drive motor left and right
Hi ,
I need a pdf for how i replace the gear unit from the drive motor. It is a Jungheinrich truck
2001
serienummer 89.91.93.97
Type EFG-DF16MPGE115-435DZ
The trucks make a horrible sound out the gear as the truck turn round the left side of right side. I think i must replace the gearbox but it is easyer as i have a manuel and partnumbers for this truck.
regards gc_d
  • Posted 10 Jun 2010 05:09
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
i agree with u , 95% cause of sensor bearing in motor made it run too slow. so pls check bearing before disassemble gearbox.
  • Posted 15 Jun 2010 19:33
  • By dai_v
  • joined 26 Nov'08 - 6 messages
  • HCM, Viet Nam
Hi Sven and Nuna,
Thanks for reply, i go to check this...
regards gc_d
  • Posted 15 Jun 2010 17:16
  • By gc_d
Regards gc_d
Hi,
before you repair the Gear Box check first the Bearings of the Drive Motors. To 95% There will be an destroyd Bearing on the Gear Box Side.
Taking out the complete Drive Unit is easiest way. Disconnect Cables / Hand- and Footbrake. Then relaese all Screws of the Gear Box and take in two M16 x 600mm stell sticks where you can shift the Drive Unit off. Thats the way.
Mfg
Sven
  • Posted 15 Jun 2010 05:39
  • By turbocabrio
  • joined 31 Aug'08 - 16 messages
  • Bayern, Germany
Hi,
Pls check your email and let me know if it can help you.
Good luck
Rgds
  • Posted 12 Jun 2010 15:07
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Thanks & Regards
Nuna
Email: nunatech2002@gmail.com
