toyota code 67-1
the switch checks good and there are no breaks in the wires. any suggestions?
  • Posted 7 May 2010 10:20
  • By garwood
  • joined 7 May'10 - 8 messages
  • Virginia, United States
Showing items 1 - 17 of 17 results.
posted by person not signed in...look for continuity between connector terminal cn122 1 and cn 104 27
  • Posted 4 Apr 2021 08:35
  • By Admin
  • joined 18 May'04 - 266 messages
  • Queensland, Australia
please help solve the problem with error 67-1. all circuits are in good order. changed the control unit, everything worked, a week later another error. found a hand brake closure, eliminated. how to repair the control box? I really hope for help. I am good at electronics. on the limit switch 9 volts. I think this is the wrong voltage.
  • Posted 12 Feb 2021 03:14
  • By Sergey_Miller
  • joined 25 Dec'20 - 2 messages
  • Kazakhstan
Code 67-1
[email address removed]
  • Posted 12 Feb 2021 03:10
  • By Sergey_Miller
  • Kazakhstan
Accumulator pressure switch open check wiring from pressure switch to connector 87 then from there to CPU board CN101
  • Posted 7 Apr 2017 07:52
  • By Paradoxical_Mec
  • joined 30 Sep'16 - 6 messages
Anyone know what error code G3 for toyota 7FBRK10 means?
  • Posted 6 Apr 2017 19:32
  • Modified 6 Apr 2017 19:32 by poster
  • By frdy
  • joined 30 Mar'17 - 14 messages
  • Indonesia
Code 63 is Tilt Lever switch abnormality...there is a lever connected to a switch on the right(sitting in the seat) Tilt cylinder....you will have to remove the cover to access the lever/switch...most of the time it is a broken mounting bolt on the Tilt cylinder....if the bolt is ok then the switch is bad
  • Posted 11 Feb 2017 10:07
I have the model 7FGU25 and I am having the same problem with my lift. error code 63. I have cleaned and tightened all the electrical contacts. still after 5 minutes of running, it throws the code.. PLEASE HELP!!
  • Posted 4 Feb 2017 08:02
  • By scott_y
  • joined 4 Feb'17 - 2 messages
Hi forum people!
I have the same forklift 7BNCU20.
I have a fault code: 1T.
I'll appreciate any help (info, manuals, reference)
Thanks in advance.
  • Posted 14 Feb 2014 02:58
  • By Luizito
  • joined 31 Dec'13 - 17 messages
Hi dude!
luiz.mit@gmail.com
Thanks dude!
I have the 67-1 code to the same forklift TOYOTA series 7 three wheel.I show all cables for any short but everything looks ok.
I have changed the controller and after three months a have the same code 67-1.
Does anyone know what maybe happen on this?
  • Posted 9 Apr 2013 15:54
  • By MikeGreece
  • joined 19 Nov'10 - 12 messages
  • sindo, Greece
mabramidis@gmail.com
email in signature
  • Posted 12 May 2010 09:59
  • By garwood
e-mail jeffrey.garwood@volvo.com
email
  • Posted 12 May 2010 04:40
  • Modified 12 May 2010 09:58 by poster
  • By garwood
67-1 is not the root cause of the failure. the mast switch can not cause travel or lift interruption. send me your email address and i will give you some information.
  • Posted 11 May 2010 10:37
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
the 67-1 is the only code that shows. the contactor picks up when you key on. but the code flashes and an alarm sounds along with the wrench light. the lift will not drive or lift. all wiring associated with the lift height switch and the switch itsself seem to be ok. battery voltage is 37.8v
  • Posted 11 May 2010 04:24
  • By garwood
67-1 Lifting height switch abnormality I
Condition for error detection
Output when open or short circuit of the lifting height switch line from the CPU board to the lifting height
switch is detected.
Lifting height
CN 130 CN90 CN92 switch
I/ input value
CPU
board
I ANL : I10 MONITOR 3-11
Check the lifting height switch I
I ' I I
I Other than MH : 00-
CN101-16(51, LS-)
1 2 - 1
1
MH : O0-
Disconnect battery plug and
disconnect CN90.
1 3 -
CN101-20(91, MH2-1)
6
CN101-19(90, MHI)
7
MH : 00- Sub harness defect
input value. (with battery plug Lifting height switch defect
6- 2
connected)
disconnect CN101, and check the
continuity.
CN101-20(91)-CN101-16(51)
CN101-19(90)-CN101-16(51)
CN101-20(91)-CN101-19(90)
No continuity
b CPU board defect
i Main
If you have need more info let me no
Regards
John.
Netherlands
  • Posted 9 May 2010 18:25
  • By johngen
  • NB, Netherlands
unless it is a symptom of some sort of cpu /ecu failure code "67-1" is not the cause of the your lift not operating. please give us some info. are there any other codes, does the main contactor close, does the park brake switch turn on and off with the handle, what is the actual battery voltage, what brought these symptoms on, any recent repairs, operator reports?
  • Posted 9 May 2010 12:42
  • By toyzilla
it is a 7FBEU20.
  • Posted 9 May 2010 10:40
  • By garwood
Type of toyota !!! its importend fot the answer
7fg are liftswitch not good
  • Posted 9 May 2010 00:50
  • By johngen
  • NB, Netherlands
Hyster
edition #1248 - 18 September 2025
UN Forklift FGL25T
UN Forklift FB25N1QZ1
October 15-16, 2025 - Amsterdam, United States
October 15-16, 2025 - Las Vegas, United States
June 30 - Jully 2, 2026 - Birmingham, United Kingdom
ASSET FINANCE
Nov 2025
