Clark c500s30 having problems starting ! igntion coil not getting spark
i cant seem to get my ignition coil to get ark. i replaces all necessary parts rotor cap coil etc. need help
engine cranks but does not fire up !
  • Posted 1 May 2010 03:10
  • By george_s
  • joined 1 May'10 - 4 messages
Hi there, I am glad I found your post and I am happy because my friend also facing the same problem and he can't find the solution anywhere. Recently, I was searching for https://fitmymoney.com/ website on google search and when I was searching for it online, I found your post.
  • Posted 28 Aug 2022 03:43
  • Modified 29 Aug 2022 22:14 by poster
  • By Janet_Shields
  • joined 28 Aug'22 - 1 message
I have same issue. When I started working on this it would start up and not rev. More I did worse it got. Now I have new points condenser new coil. I got propane coming out of the vaporizer going to the carb. I can see spark is weak. I voltage drop to the positive side of coil get 1 volt so I run. a straight wire to positive side of coil from positive side of battery. No better spark. Voltage drop ground it's all good. Battery is 12.7. It's been. running perfect for a year sense I did a head gasket. New fuel system carb vaporizer and lock off. New alternator and water pump.. Flushed radiator. I noticed lots of back firing then it got weak running. Now nothing. Compression is 125 I read in here coil case has to be grounded properly? Cleaned my spark plugs that didn't look that bad. Good blue spark. Nothing. Going after the carburetor tomorrow I hear the spring loaded slide has to move freely or no fuel goes into the cylinders and it won't start. Turned out to be the vaporizer. Too much propane. Pulled the hose off going into carb and it started. Feed less propane into hose while it's running and it runs perfect.
  • Posted 14 Jun 2022 07:56
  • Modified 19 Jun 2022 06:24 by poster
  • By Ronald_Weaver
  • joined 27 Dec'21 - 2 messages
Ron Weaver
I would put a new kit in the Distrib to start. If you have voltage going into and nothing coming out, you have a ground issue or a faulty part. If still no spark, i am pretty sure you can buy a whole distrib at a fair price. Just a thought. is the rotor turnig when the engine is cranking. Plus i have seen bad rotors, caps (even new ones)
  • Posted 14 May 2010 22:14
  • By Prentice
no spark from the dist. and there is no numbers on it at all.
  • Posted 14 May 2010 03:26
  • By george_s
What is the # on the distrib...
  • Posted 7 May 2010 22:02
  • By Prentice
is the case of the coil properly grounded and does the negative lead go to the distributor? if you open the circuit does it make a spark?
  • Posted 7 May 2010 11:01
  • Modified 7 May 2010 11:40 by poster
yea there is 12 volts its wired correctly. cash !
  • Posted 7 May 2010 09:23
  • By george_s
CASH or Cheque....... Do you have above 12 Volts going to Coil from Key Switch???
  • Posted 4 May 2010 22:45
  • By Prentice
electronic distributor i think its has like a black diode lil square thing inside the distributor. i live in the clearwater area ! looking for some help need someone to guide me in the right direction because im puzzled. and i will pay someone $100 if you can figure it out.
  • Posted 4 May 2010 02:55
  • By george_s
does it have points? are the points opening and closing properly? what part of Florida are you in?
  • Posted 1 May 2010 22:53
  • Modified 4 May 2010 10:30 by poster
