Yale OS030EC- Steering has timed out.
Serial # is C801N01668Y- The chain came off of the steering, customer put it back on and now the steering motor will not come on. After about 15 seconds the message on the display is "steering has timed out". Any advice?
  • Posted 10 Apr 2010 03:22
  • By duodeluxe
  • United States
duodeluxe
Check the proximity switch on the master drive unit, make sure when the chain came off it did not damage the switch or the wiring. Also , the chain does not normally fall off, something had to cause this. Check the drive unit and see if it turns freely without the chain connected, make sure it is not binding.
  • Posted 10 Apr 2010 05:24
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
SMV (Konecranes) 12-1200B
Enforcer FLBAXT25
