198 overheat error code
Require assistance please. Have a Still R20-18 Ser#512011016814 approx 3 mins of hydraulic use going into tilt releif error code 198 overheat appears. 48 volt system battery in good shape minimal voltage drop under load.Amp draw approx 175 amps under load. Fan for drive motor/pump motor on right side of truck operational. No blockage in venting system. Can anyone suuply trouble shooting guide for this code including voltage/resistance readings for components related to hyddraulic system for error code 198.
Tks John
  • Posted 7 Apr 2010 00:50
  • By brandy
  • joined 7 Apr'10 - 1 message
Hi Simon_k
I have the same problem on a Still r60-20
Serial number : 516022011354
Code 198 overheating
Can you help me with this problem?
  • Posted 18 Aug 2021 04:05
  • By Geert
  • joined 18 Aug'21 - 5 messages
  • Netherlands
Gevo
gevo.service.en.verhuur@hotmail.com
Hiya, Can help if you 'still' need!.
Appreciate you've probably sorted this one but if you need any future help with Still's then please feel free to contact me on simon.king3atvirgindotnet
I'm ex Still but working on all sorts now so needing a few friends in the know!
Regards, Simon
  • Posted 13 Sep 2010 02:59
  • By simon_k
  • joined 31 Oct'04 - 147 messages
  • Devon, United Kingdom
