DRIVE FAULT
LEFT SIDE MOTOR LOCKING UP. HAVE REMOVED MOTOR AND HAD CHECKED OUT , ALL OK. THIS IS A A/C DRIVE MOTOR. ANY IDEAS WHERE I WILL FIND THE FAULT ?
THANK YOU
  • Posted 25 Mar 2010 11:21
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
I have a Toyota 7FBCU25 electric counter balance. It had error code 51-1, I change both board on left side on control panel and code went away. I try driving unit but it wont past 1kpm and move very slow and battery bark blinking.
Can anyone help please.
  • Posted 20 Mar 2019 17:06
  • By everol_w
  • joined 5 Nov'17 - 15 messages
  • St. Catherine, Jamaica
If I remember correctly the sensor is in the bearing. I had no way to test it, I replaced it and everything was fine.
  • Posted 21 Jun 2016 09:35
  • By mrforklift
What does the speed sensor look like and how do you test it?
  • Posted 21 Jun 2016 02:31
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
thanks rick,
it was the sensor
  • Posted 31 Mar 2010 13:49
  • By mrforklift
lets start from the beginning, does the wheel turn freely with the motor in place. if you pushed the unit would it roll? if the answer to both of these questions is yes and the motor is still out replace the speed sensor. it is the bearing with the wires on it. it is possible but difficult to test out of the unit and too cheap to mess with. once you have determined that this is not mechanical, reinstall the motor with the new bearing and test the unit. if problem is still present swap the two controllers on the left side of the truck (sitting on it) if it is a controller the problem will change sides.
  • Posted 25 Mar 2010 23:35
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
rick c ,
how can i test the sensors, i still have the motor out.
would a fault code come up ?
there are 2 small wires comming out of the motor
thanks
  • Posted 25 Mar 2010 15:11
  • By mrforklift
the motor may be fine but most rebuilders dont know anything about the speed sensors and when they go bad the controller cant detect direction and "locked up" is what happens
  • Posted 25 Mar 2010 11:46
  • By rick_c
Mitsubishi Logisnext FD25T5M
Manitou MH25-4
