bt rolatruc e 125 fault code
hi i have a bt rolatruc (reach truck)year 2001, when driving forward or reverse it suddenly stops and dissplays fault code e 125, every thing seams to work ok, but it is doing it every 2 or 3 minuits, dose any one know what this code is, many thanks jim
  • Posted 12 Feb 2010 06:25
  • By jimmy
  • joined 12 Feb'10 - 2 messages
  • east yorks, United Kingdom
Jimmy
That is correct but I don't now, you can buy new brushes !!!!!
I did always replace the Cpl generator normaly after A wile the problem come's back.
But do good look after the wiring of the tacho !!
Regards
John.
  • Posted 13 Feb 2010 18:22
  • By johngen
  • NB, Netherlands
hi thanks for your reply, i spoke to a guy today, and he said there are some brushes in the steering generator, is this correct and can they changed.
  • Posted 13 Feb 2010 07:05
  • By jimmy
You have problems with your steering generator Look first the wiring from generator to your A 5 Card
Look after wiring 62 and 63 On A5 Card you will see numbers and leds Connector numbers 701 and 702 on print when you steering you will see that the leds on that position go on and out.
The 48 Volt for steering is 1001 Cable number 25
But mostly always the tachogenerator is not good you must replace it You can open it and cleaning it but the fault will come back soon.
Regards
John.
  • Posted 12 Feb 2010 20:50
  • By johngen
  • NB, Netherlands
SMV (Konecranes) SL37-1200A
Crown RR5225-30TT321
