Coming off of Wire guidence, it is a turret truck
The model of the unit is an EK15. It comes off the wire going forward and reverse and falls off to the right side mostly but also falls off left. Contacted Stienbach Tech. support and they sudjested to change the steer encoder on top of the drive motor as it wont stay calibrated and I have done it the past with good results. Changed the encoder and it wont stay calibrated still as it works good at first then falls off the wire. Have tripple check electrical connections and done everything the tech guy has said to do but nothing has worked. The tech. guy is fed up with me calling him so much but that is what he is there for and he is not given me anymore answers. Could be a faulty IFP card but not sure as this is an intermittant problem.
  • Posted 7 Feb 2010 11:20
  • By BenH
  • joined 17 Aug'09 - 27 messages
Did you ever get this turret truck figured out? I might have some hints for you, I work on two of these but do have one right now that guides straight but never goes full speed with the guidance switch on and the light never goes solid green.
  • Posted 16 Sep 2010 10:22
  • By darwin_t
  • joined 5 Jun'09 - 4 messages
  • Wisconsin, United States
Hawker Powersource, Inc.
