code GB or 6B
Serial number EF-A-05-32904 I'm getting code GB or 6B when the machine is moving and unloaded, operator re-sets key switch nd will work for a bit and code out again, everything is disabled and the alarm sounds. This unit has a built in scale with read out. When the code came up, the readout was at 50lbs, when reset went to 0000. Any help?
  • Posted 18 Dec 2009 05:41
  • By Barfly_olaf
  • joined 10 Oct'09 - 81 messages
  • Nova Scotia, Canada
SEMPER FIDELIS
if i remember correctly they are located under the front wheel plate
test i18 checks for the input of those switches back to the vehicle manager
  • Posted 24 Jan 2010 05:20
  • Modified 24 Jan 2010 05:21 by poster
  • By RookieTech
  • joined 22 Oct'07 - 4 messages
TKS for the reply, are the switches located on the caster wheel, and what is teat i8
  • Posted 19 Jan 2010 01:25
  • By Barfly_olaf
SEMPER FIDELIS
there's no code 6b
gb-caster wheel input sensor failure
check the switches - s61 and s62
check switches, bracket and wiring
run input test i18
  • Posted 16 Jan 2010 08:50
  • By RookieTech
Mitsubishi Logisnext FD25T5M
Airman ENCL045
