Brake stuck
I am trying to get an old Clark runnibg. It has been standing for 3 years. One drive wheel is totally locked, other is fine. I rebuilt the mastercylinder and bled the system. It released the stuck wheel a little but it was still draging. I pressed hard on the brake pedal, felt a click and the wheel locked up again. I opened brake bleeders to check operation of mastercylinder and it felt fine. One wheel turns freely, the other aboy 1/8" Help please!
  • Posted 17 Dec 2009 07:33
  • By farrel_b
  • joined 17 Dec'09 - 3 messages
  • British Columbia, Canada
Thanks Edward. The push rod on the master cylinder has lots of free play so its internal. if anyone has a book for an older model 5000 lb Clark propane ride on ot would be greatly appreciated. My email is [email address removed]. (EVEN POTOS WOUD HELP)
  • Posted 17 Dec 2009 13:20
  • By farrel_b
ahh, the fun of "inboard brakes" this brake system will require considerable effort to get into, and pretty much explains your reluctance to have to dig into the brakes.
at this point I would want to insure that there really is enough free play in the mater cylinder rod to be sure the master cylinder is allowing all the brake fluid to return.
Getting into this brake system is not a fun or trivial job, and not a good one for anyone who has not done one before to try without either someone who has done one before, watching to make sure no one gets hurt (and to help "man handle" the assembly which is close to or over 100 pounds) or at the very least has the book to see what they are getting into.
If someone does have a book for this truck, and they would be willing to share the parts about the brakes with you, they will need an e-mail address, and you can not post a properly formated e-mail address on the forum, but you can add it to your profile.
  • Posted 17 Dec 2009 10:58
  • Modified 17 Dec 2009 11:01 by poster
many thanks for info, I pulled the wheel but there is just the shaft with tapered bearings and a gear which drives the wheel, no brakes? Where are they
  • Posted 17 Dec 2009 09:48
  • By farrel_b
pull the wheels off, don't try and do a 1/2 way job with forklift brakes, just bite the bullet and do it right, one time only. you may only have to sand off the rust, (if it was me I would change the wheel cylinders, after a few years it will need it) but wouldn't be better to be sure than to have someone hurt?
you do have free-play on the shaft that pushes the spool into the master cylinder when it is "at rest", correct?
  • Posted 17 Dec 2009 08:54
  • Modified 17 Dec 2009 08:57 by poster
