toyota forklift mod 7FGU25
CEHCK ENGINE LIGHT ON IN THE GAUGE CLUSTER, ALREADY FOUND CUT WIRES AND HAVE REPAIRED THEM, ANY IDEAS?, ALSO CHECKED THE USUALS OIL, COOLANT, DISTRIBUTOR, ANY HELP WOULD BE GREAT
  • Posted 16 Dec 2009 04:57
  • By damien_j
  • joined 16 Dec'09 - 5 messages
  • Hawaii, United States
thanks rick i will try it trw
  • Posted 4 Jan 2010 15:49
  • By damien_j
this one is a little more complicated but try this first: there is a 1/4" id hose at the base of the lp regulator low pressure cover that connects to the plastic resonator box. take it off of the regulator and see if the problem improves. if it does send me your e and i will send you some info.
  • Posted 31 Dec 2009 11:55
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
thanks rick, i will check those wires, im also working on a 7fgu18 that has an idle problem, rebuilt the fuel accumulator, new plugs, wires, cap and rotor, the lift was surging up and down on idle then I cleaned the carb, no surging but idles high, when I turn down the idle the machine begins to surge again, I have looked for vacuum leaks but have found none. I also disconnected idle switch which lets the machine operate at a lower idle, but then the check engine lights turns on. any ideas thanks for your time
  • Posted 31 Dec 2009 11:37
  • By damien_j
Vacuum switch. Left side of carb. Probably broken wires.
  • Posted 30 Dec 2009 23:24
  • By rick_c
hey rick
thanks for the help, the light blinks three times
  • Posted 30 Dec 2009 21:32
  • By damien_j
if the light is engine outline shaped and on the upper right side of dash there is a test point beside the battery. loose pig tail 6 pin connector black in color. when you find it hold it with the holes facing you and the lock tab on top and jump the bottom row left two terminals count the flashes with key on. let me know.
  • Posted 18 Dec 2009 03:00
  • By rick_c
Mobicon 2T
Maxlion R2D35
