Linde
We have two Linde H45D-600-04;2003 model year at our plant. These two units also have cabs with A/C. We are located in the desert where temps. reach 105 - 120 degrees in the summer. Can anyone tell me what to expect as far as break downs and parts I might want to stock?
  • Posted 18 Feb 2006 05:55
  • By cownd
  • Arizona, United States
Im guessing the A/C condenser is sitting on the counterweight ?
keep this cleaned out..........wash it out daily when its in constant use.... after washing make sure it's dried out before you fire it back up
same goes for the evaporator if its easy access...only you dont need to dry it out after cleaning
also have a spare A/C compressor drive belt on the shelf
  • Posted 31 Jan 2007 14:01
  • By ratchet
  • joined 8 Jan'06 - 11 messages
Right then, previous experiance of these machines i would recommend the flowing parts.
Water pump and gasket (bearings fail due to dust build up on pulley).
Starter motor and relay, bottom mast anchor rose bearings, 'o' rings for the two feed pipes into the squash plate housing.
(these are special high preasure rings)
Horn push, Key switch and hoses (you will need the mast number when ordering).
Service filters (donot clean or change the air filter until the indicator says so)
Providing you grease and carry out regular maintance these machines should give you good service.
  • Posted 25 Feb 2006 11:39
  • By adrian_w
  • joined 18 Nov'05 - 33 messages
  • East Yorkshire, United Kingdom
Premier Mechanical Handling,
Hull.
UK
Perkins
  • Posted 24 Feb 2006 08:11
  • By cownd
Are they the X model ie has a diesel vw engine or the perkins engine?
  • Posted 24 Feb 2006 07:46
  • By adrian_w
Hull.
UK
Komatsu FD25T17
Rail King RK330
