poor starting when hot
has anybody had trouble with h60d being bad to start when hot , after being left for 20 mins or so. truck starts fine from cold and runs fine when running but operator says it will turn over and over for a good while before it starts when it,s hot. never misses a beat when i get near the truck. trucks about 18 months old. cheers
  • Posted 11 Nov 2009 05:58
  • By kevin_k
Hook up jumper cables and jump it. if it starts every time you may have a voltage drop. load test battery,Had a LP unit do this and battery load tested 6 volts and engine turned over great.If it has a crank sensor do resistance test. you wont always get a code. electronic part could be breaking down
  • Posted 24 May 2015 07:15
  • By edward_m
  • joined 11 May'15 - 111 messages
SMV (Konecranes) 4538CCX4
SNORKEL A46JE
Kai von Berg Kai von Berg
