H code
S/N 2EC360748
Drive motor was installed in this unit, unit drove fine. A mechanic hooked up the drive brush wear indicators after that the dash shows an H and is dead in the water. Does anyone know what to check?
Thanks
Jimmy
  • Posted 16 Sep 2009 05:14
  • By VXman
  • joined 14 May'09 - 34 messages
  • Oklahoma, United States
my book for this unit does not show an error code "H". Are you sure about the serial numbers and model number? What happens if he tech disconnects the wires for the brush wear indicators?
In the New A/C versions of this truck, an "H" is most often an error code that relates to the hydraulic levers not being at 'zero' when the truck is first turned on. for that reason, the first thing I would check is to see if any of the switches for the hydraulic control valve are "made" (closed contact) when at rest.
  • Posted 16 Sep 2009 06:44
  • Modified 16 Sep 2009 06:45 by poster
REPOWERTEK Inc
Terberg RT403
UN Forklift FBT18NQZ1
