code 51
some can helpme with code 51?
  • Posted 15 Jul 2009 22:42
  • By josh_g
  • joined 15 Jul'09 - 1 message
  • Illinois, United States
The part numbers are the same on the box between the new style and older style drive pots.
  • Posted 19 Sep 2014 10:45
  • By JimConnected
  • joined 23 Jun'11 - 15 messages
can you tell me the part number for the new type accelerator switch?
Thank You
  • Posted 15 Sep 2014 01:35
  • By doug_d
  • joined 10 Sep'14 - 1 message
The failure point in the accelerator assy that caused the code 51 was always the start switch wiper..therefore the temporary fix of adding on an external mechanical start switch. There is now a new accelerator part number that seems to have rectified the problem. No need now to do the temporary fix of the external start switch.
  • Posted 14 Nov 2013 23:00
  • By Techtrainer64
  • joined 26 Aug'10 - 46 messages
  • Kentucky, United States
If you want a copy of the procedure...drop me a line at chriskieninger@ gmail.com
  • Posted 31 Oct 2013 05:24
  • By theforkliftdude
  • joined 7 Jan'11 - 14 messages
  • Wisconsin, United States
As a side note.....this is only one of a few fixes....code 51 can also be caused by a mis adjusted pot, and they have also found bad splices in some of the accelerator harnesses...in the negative wire....the mod dosent really "bypass" the accelerator switch, it just provides for mounting an external accel switch...the ones internal in the pot are prone to failure
  • Posted 31 Oct 2013 05:23
Swoop......I dont see any numbers on the paperwork...I got it from the cat dealer I used to work at....but it includes theparts list and part numbers....even a couple of pics....iIim more than willing to share copies....just get an email address to me.....and I can scan Iit and send.....ive done it numerous times....so far worked everytime
  • Posted 31 Oct 2013 05:19
Had this code 100 times! replaced the pot each time. Always found thew "on" switch part erratic. Had many trucks with same thing. New pots right out of the box were bad. So, one day i got fed up and took one apart. Cleaned it, tightened the spring wipers then glued it back together. Lasted 2 years. Did all other trucks. Cheap fix that works
  • Posted 27 Sep 2013 11:24
  • By EasiTek
forkliftdude,
is it a mcfa TC, hpk or psb document from them?
if so what is the media number on it?
i did not see any of those when i was looking through my information.
That seems rather odd mcfa would approve a fix that would bypass a component, they generally find a better component and just update it with the replacement.
  • Posted 20 Sep 2013 21:19
  • Modified 20 Sep 2013 21:26 by poster
There is a procedure...im holding a copy of it in my hand.....it is not an updated pot....it involves welding a small plate on the bottom of the floorboard and mounting an accelerator switch to it....then wiring it into the harnessto bypass the accelerator switch that is internal in the pot
  • Posted 20 Sep 2013 03:27
cat update hpk articles do not indicate any updated accerator pot that includes installing an external switch that i can find.
But code 51 does involve replacing the potentiometer or repairing any wiringi issues or abnormalities in the accelerator circuit or pedal assembly.
make sure the pedal is returning completely back when released.
if any wiring is found to be chafed or broken repair the wiring
if all else fails then replace the accelerator potentiometer and set it up according to cat adjustment proceedures.
Note: installing an external switch negates any safety protocols and should not be done in ANY case.
  • Posted 6 Jul 2012 21:46
  • Modified 6 Jul 2012 21:47 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
there is an update for the pot..it will cure the problem...involves modifying the harness and installing an external accel switch
  • Posted 6 Jul 2012 14:44
