H25D
Evening all, H25D 1991 model steering link pins and bushes. I thought these where going to be dead easy, that was untill I started the job, absolute nightmare nothing would shift and then all the new bits where just as tight. anyone else got experience with these?
  • Posted 14 Jul 2009 07:52
  • By oilslicknick
  • joined 7 Mar'08 - 13 messages
  • cornwall, United Kingdom
Any chance of a pic of the press set please.drove me to drink the first steer pins I did.ended up taking axle out. kbprotec at Hotmail dot co dot uk this kevin
  • Posted 15 Nov 2015 07:00
  • Modified 15 Nov 2015 10:31 by administrator
  • By kevinw
  • joined 21 Aug'14 - 7 messages
  • s york, United Kingdom
I do this out in the field. auto parts has a ball joint service kit, looks like a big seaclamp. jack up rear of truck about 3 feet and knock out roll pins, place c- clamp on pin and use impack to push pins up. and do the same to in stall.pull steer cyl and repack and reinstall in say 4 hours
  • Posted 24 May 2015 04:38
  • By edward_m
  • joined 11 May'15 - 111 messages
..Simon, I would love to get a pic of that press that you speak of, It surely would help out in my build!
Regards
R orangetractoratsbcglobaldotnet
  • Posted 19 Apr 2013 04:29
  • By ctforkliftguy
  • joined 14 Mar'13 - 48 messages
  • Connecticut, United States
Hi Simon sent message to your email cheers herald
  • Posted 10 Oct 2009 04:50
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Hi Simon, a pic of your set up would be good you can send it to [email address removed] cheers mate
  • Posted 9 Oct 2009 08:47
  • By oilslicknick
Simon_K:
Nick, I'm sure you've got the idea about what sort of press you need but if you like I can send you a pic. I used a mast cross brace and tilt box to make mine,then add a big bottle jack and a few different length M14 bolts then sorted!
Can I get this picture. Please send it to my e-mail address in my profile. Thank you!
  • Posted 9 Oct 2009 07:19
  • By Billy_B
  • joined 18 Feb'09 - 45 messages
  • Slovenia, Slovenia
  • Posted 9 Oct 2009 06:04
  • By simon_k
  • joined 31 Oct'04 - 147 messages
  • Devon, United Kingdom
First thing I did when I started for my new outfit was make a **** press!! lol. Still use the same axle in the mid range machines and your shafted without a 20 ton bottle jack and a good pressing arm!!. The difference between a days work and 2 hours!.
Anyway... Hiya Herald!. I remember talking to you some time ago about the job scenario down here in sunny devon as you were pondering a move. Was wondering if your still curious as the newish company I work for now need another engineer ( I'm **** flat out!! lol). If so bung me an email at simondotking3atvirgindotnet
If you could chuck us a mail even if it's not for you I'd be grateful!....
  • Posted 9 Oct 2009 05:46
  • By simon_k
Hi nick
glad you got it sorted,it does look a easy job when you start it,often thought the roll pins to hold in the link pins are a bit unneccasary,never seen one fall out,if only.
herald
  • Posted 17 Jul 2009 08:53
  • By Herald
Hi Herald, thanks for that, I guessed they where probably a shrink fit, it took a good few tons on the press to take it apart but i got there in the end and then had the new parts machined to give an easier fit. Regards, Nick.
  • Posted 17 Jul 2009 08:23
  • By oilslicknick
Hi nick
Yes the pins in the link bushes will need to be removed with a press and also the new ones pressed in,i have got them out with a hammer but its easy to mushroom the ends and make the job even harder.
Linde build the axles with the pins put in at a VERY low temperature then as they warm up they tighten up,
cheers herald
  • Posted 17 Jul 2009 07:58
  • By Herald
Linde Material Handling
Enforcer FLBAXT25
Terberg YT220
Enforcer FLBAXT25
Terberg YT220
