Chain whip / lift cylinder damage - information needed
Does anyone have any literature or even video that demonstrates how chain whip damages (scores) lift cylinders?
  • Posted 5 May 2009 20:49
  • By mrbunngle
  • joined 5 May'09 - 2 messages
Apart from what normandy described i have seen this on a lot of reach trucks.....mainy after a lift ram seal change..if the rams are not bled properly u get a bouncing effect..also settings in the controller [parameters ]letting to much oil by pass solenoid valves ,,,,especially with full load ,,it would help to no what brand ;;
  • Posted 7 May 2009 04:16
  • By DAMO
  • joined 9 Jan'07 - 196 messages
  • DUBLIN, Ireland
If the chains are scoring the Cylinder rods there are 2 probable causes,
1 the chains are not evenly tensioned allowing one to be slack and rubbing against the cylinder rod when traveling.
2 the operators are lowering the forks too soon while retracting from a pallet, binding on the pallet and allowing the chains to go slack. This will inevitably allow the chains to come into contact with the Cylinder rods, with the results you suggest.
I am sure there are many variations of this theme but the net cause will probably be loose lift chains
  • Posted 7 May 2009 00:41
  • By Normandy
  • joined 28 Sep'06 - 186 messages
  • Co. Cork, Ireland
if you cant fix it with like a 400 grit or its deeply scored youll need to replace the rod or have it re-chromed
  • Posted 6 May 2009 12:16
  • By justinm
Terberg RT403
Elwell-Parker ESI500-36
