Diagnostic cable for Still truck Rx20-20
Dear all Still Experts,
I have the canbus cable which use for connecting to the FMx reach truck (AC version - 2007) but I don't know if I can use it to connect to the Still Truck RX20-20 (Year 2007) or not ? Someone can help me.
Looking forwards to your advice
Thanks in advance
Regards
Nuna
  • Posted 4 May 2009 17:20
  • By Nuna
  • joined 12 Mar'09 - 189 messages
  • BK, Thailand
Do i need to update software? or just replace inverter....
  • Posted 30 Jun 2016 02:07
  • By TANTADRUJ
  • joined 13 Oct'13 - 104 messages
  • ljubljana, Slovenia
Hello, thanks, someone else said the same.... i'll replace left side converter and see if any better...
where do you find this info in steds?
  • Posted 27 Jun 2016 06:22
  • By TANTADRUJ
Hello.
A38-40 Internaø process error inCPP. Configurarion error (parameters). impermissible CPP channelor output configured sevaral times. chek parameter.
A39-14 - FU2 communication error. SR cannot receive PDOs on time. Drive unit is locked, no drive function. most likely the MCU. Traction converter fore the left side.
Hope it helps.
  • Posted 27 Jun 2016 06:06
  • By sjoold
  • joined 24 Oct'15 - 25 messages
  • Norge, Norway
I will ask here for help...
Also have RX 20-20. After a few minutes of working with it the forklift stops. Wont go any direction and also hydraulic wont work anymore. Has 2 errors:
A3914
A3840
Is it problem traction inverter?
  • Posted 23 Jun 2016 06:30
  • By TANTADRUJ
Hi Nuna,
for diagnostics you need different cables for the Rx and FMx trucks. FMx uses dongle + cable and Rx uses canbox and two cables. The canbox is located within the diagnostic case and the dongle is a seperate unit - it connects to the laptop USB port.
Sorry, you have to spend some money....
Hope this info is of some help
Regards
J
  • Posted 22 May 2009 06:30
  • By JBrad
  • joined 3 Feb'09 - 14 messages
  • Lancs, United Kingdom
Lift Tek Elecar
Komatsu FD25T17
Taylor T520S
