main cilinder in mast (# D-30389) does not lower, unless i add about 130 lbs of weight
I removed the chains and the carriage lowers with no problem, the cilinder does not lower i disconnect the hidraulic hose from the control valve and the cilinder itself, and it will not lower i have to add weight in order for the cilinder to lower, Is there a check valve inside the cilinder? or is the packing keeping it from lowering?any suggestion before i repack the cilinder? it lifts ok and does not leak.....
  • Posted 30 Apr 2009 14:35
  • By marc_a
  • joined 19 Feb'09 - 31 messages
  • Baja California, Mexico
i found that the pin holding the check valve inside broke damaging the gland and i had to replace the cilinder shell and the gland at the bottom it works great now
  • Posted 8 Aug 2009 17:18
  • By marc_a
Esie Cortez Esie Cortez
Hyster
Oxford Ct, United States
