Combi lpg not sure on model yet
Customer has called saying the truck was using 2 bottles of gas in 4 weeks now 2 a week same work last engineer looked and told them the transmission was us it makes no sense to me at sure it's more gas units at fault ?
  • Posted 6 Nov 2025 02:45
  • By mobbsy
  • joined 30 Apr'13 - 12 messages
  • Cleveland, United Kingdom
thanks imobbs
I do have a direct No for a tec at Combi just thought I would try to get some thoughts on it before I go and look tomorrow I just can't see how the truck operates as normal and uses so much more gas is a transmission fault as last company have told customer to me it's more a gas system or maybe engine related fault
  • Posted 6 Nov 2025 04:44
  • By mobbsy
thanks imobbs
Hi
Not sure of the specific issue and or age of your truck, but Combilift have a dedicated Technical Team covering the UK. If you still need support, you can complete a quick technical support form at the bottom of the main combilift.com web site or direct link https://warranty.combilift.net/technical-support-form/. The form only asks for the minimal info so the team can quickly help you. There is no login required and no charge for this support.
The UK Tech Team will be back to you quickly. Hope you get sorted quickly.
  • Posted 6 Nov 2025 02:58
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
