NO AUXILIARY FUNTION
I NEED AID WITH THIS MACHINE SINCE SYSTEM CARD DOES NOT SEND SIGNAL BY THE PS10 TOWARDS THE SELENOID, REPLACE CONTINUOUS SYSTEM CARD AND WITHOUT VOLTAGE
EZ-A-02-24376
EASI DR30TT
  • Posted 5 Jan 2009 10:33
  • By jose_m
  • joined 5 Jan'09 - 13 messages
  • d.n, Dominican Republic
That filter is for add-ons like scanners and computers. Are there any Add-ons? You must check for shorts to frame. With battery unplugged, there should be high resistance from neg or pos battery terminal to frame 10,000 or under can be a problem. If there is nothing hooked into this, check for shorts by wiggling the harness. Coffee or soda pop in the display will also cause this.
  • Posted 30 Jan 2012 00:09
  • By EasiTek
have a raymond Easi EZ-A fuse at filter card assembly keep blowing and no reach.
will a 15A slow blow fuse fix the problem ?
thanks thanks thanks.
  • Posted 14 Jan 2012 07:14
  • By hellokitty
  • joined 11 Mar'09 - 86 messages
echo3618@hotmail.com
Depending on the model and version its either under the top cover by the control handle (most common), under the main side control panel or in a few instances by the hydraulic manifold on the left side..
It takes a SLOW BLOW fuse..
  • Posted 3 Jun 2011 10:32
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
I can't remember where on the EZ Reach it's located but look for a small potted module or black box about 4" square with a pop out fuse holder in the face. Pop the fuse out and check it with a meter. If it's blown make sure you replace with a 15 amp slow blow fuse. Also make sure your overmast cables are good.
  • Posted 2 Jun 2011 22:54
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Justin -Im having the same problem -I have eliminated the handle, 5 & 8 driver boards by plugging in good parts from a known good forklift. Where is this "filter assembly"??
Thanks -Troy
  • Posted 2 Jun 2011 10:29
  • Modified 2 Jun 2011 10:30 by poster
  • By troy_m
A-Lift Services -- safe -reliable -affordable
yeah it was the fuse in the filter assembly
if you have that fuse fail youll have no aux functions and no codes
thanks to an unnamed friend of mine at raymond for the heads up on that
  • Posted 13 Jan 2009 13:58
  • By justinm
E L IFT thanks to already help me resolvi the problem with the aid of justin mcentee
  • Posted 9 Jan 2009 11:56
  • By jose_m
were the coil driver cards replaced with the system card?
there is a 5 and 8 coil driver cards that have the transisters that provide power to the solenoids.
does the pump come on? if not are you sure you're getting input from the control handle switch?
  • Posted 9 Jan 2009 00:39
  • Modified 9 Jan 2009 00:41 by poster
  • By E_lift
  • joined 9 Dec'08 - 15 messages
REPOWERTEK Inc
Taylor TE650S
Taylor T520M
