Linde V10 Error Code 132
Would anybody be able to advise the error code description for error listed below.
Unit operates ok, but once lift basket and then come to lower it will creep extremely slowly down. lift is disabled at this point, once fully down will be able to lift again at normal speed but lowering repeats issue and error code below.
Err 132
V10
615212f00288
11/2015
Any help greatly appreciated.
  • Posted 30 Oct 2025 21:38
  • By Lordmoss13
  • joined 3 Jul'20 - 16 messages
  • Wales, United Kingdom
Powerlift Materials Handling
attached a screenshot of the sensor. Is attached to a thin cable.
This post contains images that are pending approval
  • Posted 6 Nov 2025 17:59
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
FE132: Error in the evaluation of the digital end analogue signals for height measurement
possible causes: too fast lifting or lowering, nu impulses during lift or lowering
you can check the wiring, height sensor, (and switch maybe?) or else you need software to teach in
  • Posted 6 Nov 2025 17:43
  • By frits_f
