Good afternoon I'm having a hard time trying to lower the speed to 7 mph on a 1F2. Any help would be appreciated. Thank you
Not always , I worked for a Nissan dealer and we had to add the sensors even if they had the new digital dash I was told you have to order with speed sensor it is an option not standard
So make sure it is installed or it will not slow down
Search youtube for nissan forklift dash code its the same as unicarrier. Once your in go to SET then VCM. Scroll down till u see speed Li and speed Lo. Change Li to the speed you want then change speed Lo to the same speed.
Ok thank you going to look for it.
Hello that would be great if you can email me some info. My email is oscarq48 at gmail dot com thank you
hi i am sure that speed sensor is fitted as standard if the unit is fitted with digital dashboard and you have up down arrows and enter button you have to set through the dash board you need acces code to dash and then you can access the three different programs you then have to search for the specific speed setting i can help with that if that is the case i can email that to you
Look on right hand side of trans about 3/4 way down see if there is a switch with wire to it
It may have a plug if no speed sensor
If no sensor you need to get one from dealer and install be forewarned you will lose trans fluid unless you do it very quickly and even then you will lose some
After you get it in then you can set speed
