Genie s85 not detecting sensors after engine replacement
Hello, I did a engine swap on a Genie s85. The original engine was a Duetz td2.9 l4 and it was replaced with the same model. The problem I am facing now is that it will start, but it shuts down due to coolant level fault. Does the control module need to be reprogram whenever an engine swap is done even if it is the same model?
  • Posted 20 Sep 2025 02:33
  • By Imami_F
  • joined 20 May'25 - 1 message
  • Ghana
Oxford Ct, United States
Esie Cortez Esie Cortez
