Converting from gas to propane
Looking at buying a tennant 800 sweeper with a gas engine. Curious about how difficult/expensive it is to convert to propane
  • Posted 31 Jul 2025 22:07
  • By Jim_Chaput
  • joined 7 Nov'24 - 4 messages
  • Wyoming, United States
Jim Chaput
What motor is in the machine to start with? Then does the motor operate with an ecm? Coil packs? If it's old school points and condenser. It's probable to convert. I'd start there. Any electronics that fires the ignition side along with fuel most likely not doable. If not it would take some measurements of intake components and if water ports are available. Needed for the vaporizer. Impco technologies can match up anything to fit your needs. They sell kits for this purpose. Measure for airhorn, throttle cable position, horsepower needed. That would tell you size of mixer. Ca55, ca50, etc. needed fuel for power. Intake opening, stud center to center. Updraft. Down draft ! What is on for a carb now. Sits on top of intake? Then downdraft. It's a real basic system. Room for a tank holder etc. fittings are basic if you know pipe thread and gas thread. Gas thread is different and brass only. 12 volt solenoid for shut off of LP. Hope this helps.
  • Posted 8 Aug 2025 08:40
  • By ron_k
  • joined 2 Apr'15 - 124 messages
  • North Dakota, United States
4kliftman
It is medium price, if you are experienced.first you should be certified
For LP ,second you need an LP kit and knowledge of L P and lastly if you are not familiar with LP/ gas conversion you really should get a qualified tech experienced in
Conversion to do it. So to summarize it can be expensive if unqualified and also dangerous
I have done dozens over the years and am licensed through state of Texas for repair/ installation you need to check state regulations
On installation requirements and licensing
  • Posted 7 Aug 2025 22:26
  • By John_Bradley
  • joined 10 Aug'22 - 268 messages
Jb69
Enforcer FD50T-MMA
SMV (Konecranes) 4632CC5
RAEDER-VOGEL
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
