Linde E16C-01, 386 series, Error L342 and L341
Hi,
After switch on the truck, the display remain normal and it's hydrualic motor keep running then error L342 appear and after some time the error L341 pop-up along with L342.
I have checked the accumulator, no oil comes and hissing sound which means the accumulator is fine. Now the both pressure sensor 3B3 & 3B4 giving output voltage on volt meter and the coil 2Y10 also fine.
Note: the hydraulic motor keep running.
Please help me in this rgards
  • Posted 11 Jul 2025 18:21
  • By Syed
  • joined 14 May'15 - 194 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
L342= Pressure sensor signals not correct in relation to each other
  • Posted 20 Jul 2025 07:27
  • Modified 20 Jul 2025 08:54 by administrator
  • By marksmith
  • joined 26 May'25 - 17 messages
  • United Kingdom
forkliftmanual.com
Your code is pressure in accumulator greater than 60 bar check the pressure sensor and wiring to sensors and controller may have open connection
  • Posted 18 Jul 2025 04:47
  • By John_Bradley
  • joined 10 Aug'22 - 260 messages
Jb69
You might have a bypass in the brake system that's drawing all the pressure from the accumulator.
This happened to me on a 387 truck.
Regards
  • Posted 15 Jul 2025 16:25
  • By Dureado_Agarate
  • joined 7 Nov'24 - 5 messages
  • Mexico
Insanity is doing the same thing over and over again and expecting different results
can anyone share the detail description of error L342?
  • Posted 14 Jul 2025 07:55
  • By Syed
  • Sindh, Pakistan
Jim Tompkins Jim Tompkins
Sales operations, Heli
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
