H 60FT 2000-12 code
My boss just spent a bunch of money and the mechanic didn't fix our problem. The error code was intermittent and could be reset by disconnecting the battery for a few minutes. Now, the code stays and the forklift will not start. The dealership tech that we like is on vacation and I'm trying to see what I can do in the meantime. I've read on this forum that the code is something to do with the canbuss connector. Where do I find the can buss connector? I'm not a forklift mechanic and I don't play one on the internet.
  • Posted 10 Jul 2025 00:33
  • By Wade_Betts
  • joined 10 Jul'25 - 2 messages
  • United States
FIXED!
I spent about an hour looking for the second terminal resistor. On that machine, it's located by the air filter housing. With the key on, when I moved the wires connected to the resistor, something clicked in the engine compartment. Aha! After some fiddling, I determined it was the wire going into the fuse holder marked ignition that was shorting out. A new inline fuse holder from the NAPA store, and we were all fixed. If it wasn't for this forum, I would have never have been able to get the lift back in service. Thank Y'all.
  • Posted 11 Jul 2025 02:31
  • By Wade_Betts
  • United States
From Admin- Demetry_r has previously posted...
Hello all,
I have just spent the last two weeks troubleshooting two of my Hyster S60FTs throwing the 2000-12 Code. This morning I have found my solution and am posting this the point anyone else with this issue in the right direction.
After checking voltages and the CAN loop to the ECU VSM and DSC and finding nothing wrong there, I had a random brain wave that pointed me to the ECU connector if you have the SICMA 90 way ECU connector the pins get worn out and loose inside the connector so they don't make contact to the ECU after crimping new pins in the connector it roared right back to life.
If you have any questions please feel free to post them below! :)
Hope this helps anyone else in this situation!
Cheers!
Posted 10 Apr 2018 21:53
By demetry_r
joined 10 Apr'18 - 2 messages
Ontario, Canada
  • Posted 10 Jul 2025 09:31
  • By Admin
  • joined 18 May'04 - 266 messages
  • Queensland, Australia
