Crown MT20 electrically dead mid lift
So I had an operator lift an overweight pallet with this Crown MT20 walkie stacker. As soon as he hit the second stage of the mast the unit died and smoke was generated. I don't understand why this killed the whole unit. Is there a master fuse anywhere? Any suggestions would be welcome. Thanks! Mikey
  • Posted 27 Jun 2025 05:55
  • By MikeyB
  • joined 27 Jun'25 - 1 message
There is no fuse for the lift motor on this model of lift. Most likely you burned out the lift/hydraulic motor. If it was an over weight that would explain why the whole unit it was killed. It is possible that the batteries are also experiencing issues after drawing too much amperage or there is additional damage inside the lift.
The weight limit on forklifts is something that should never be exceeded. More modern lifts have better protections, but these older models do not have many protections at all.
  • Posted 27 Jun 2025 21:59
  • By DyslexicNerd_01
  • Wisconsin, United States
Sue Tomic Sue Tomic
