Backfiring
I have a 2018 toyota 8fgcu30. So we replaced the vaporizer because old one had a hole in diaphragm. It's been a month since we replaced it. It starts and runs smoothly but when you start driving it, it eventually backfires through the air filter. It literally blew apart the secondary air filter. What could be causing this? Any help would be appreciated
  • Posted 10 Jun 2025 23:35
  • By Vernon_Jackson
  • joined 7 Jun'22 - 14 messages
Vernon
So the problem is the little solenoid valve that comes with the mixer. There was a short in one of the wires ans the plug. Replaced the plug, wire and solenoid valve. No more issues.
  • Posted 20 Jun 2025 03:44
  • By Vernon_Jackson
Vernon
Also check the diaphragm in the mixer , have seen a lot that stick and cause the same issue
  • Posted 20 Jun 2025 02:27
  • By John_Bradley
  • joined 10 Aug'22 - 271 messages
Jb69
Normally most backfire problems come from some problem with the ingion system l would check the cap roter wires and plugs. check your coil and pick up. Very rarely but possible a intake valve could cause this. would have to be on the intake because you said it blows the air filter cap off. if it were backfiring from the muffler l would say it is a exhaust valve. with that said I myself have never seen that on a late model Toyota.
  • Posted 14 Jun 2025 22:15
  • By Scott_
Scott
I saw that happen with faulty ignition wires
  • Posted 14 Jun 2025 21:14
  • By Fritzthecat
  • joined 20 Oct'23 - 23 messages
  • Connecticut, United States
Be nice to forky
