Erratic crank, no start
CG30G with Mitsubishi 2.4L engine. LPG. Randomly stopped and now when cranking, engine will crank for about 1 second and then drop out, then crank again and so forth (with key held in start position the whole time". Not showing any engine light. New cam speed sensor and crank speed sensor. No blown fuses or relays.
  • Posted 5 Jun 2025 12:21
  • By Tech_help
  • joined 5 Jun'25 - 1 message
  • New South Wales, Australia
Check battery , if low voltage it will let starter turn then drop out Clark lifts do same thing when battery is bad can't boost them either
Another check would be the start relay weak and dropping out
  • Posted 5 Jun 2025 23:22
  • Modified 5 Jun 2025 23:23 by poster
  • By John_Bradley
  • joined 10 Aug'22 - 268 messages
Jb69
UN Forklift FD15-18T
SMV (Konecranes) 4632CC5
