Excessive crank case pressure.
We have this H50xm, with the 3.0 liter GM engine. We have replaced the PCV valve, the filter that connects to the oil fill cap, and replaced all the vacuum lines to where they are supposed to go. And yet there is a considerable amount of crank case pressure building up. Any ideas why this might be happening?
  • Posted 30 May 2025 03:15
  • By Stanley_Darland
  • joined 14 Jun'23 - 2 messages
  • Oregon, United States
Stanley D.
I my self have not seen that on a 3.0 motor but does the truck have a lot of hours of run time. It is possible that the engine is worn on the bottom end might have a ring problem will cause a lot of blow by. Is this truck running on lpg or gas more likely would happen if tuning on gas as gas would wash at the piston ring faster than lpg as it is coming in as a liquid try taking a leak down test if you have the gauge and a compression test that should tell you if the engine is worn. good luck.
  • Posted 31 May 2025 22:50
  • By Scott_
Scott
SMV (Konecranes) 33-1200C
Unicarriers FD80-2
Lift Technologies Inc.
